Exposé hotkeys (F9, F10, F11, F12) may conflict with preset Maya hotkeys. If you experience this problem, you can change the Maya hotkeys, or change the Exposé hotkeys in the System Preferences panel of the computer running Mac OS X.
Hi @Anonymous
The easiest solution would be to change the hotkeys to a different key or combination of keys like shift+F11 for example.
That said, if you open the system preferences for your Mac and try to change the keys like the suggestion says does that not do anything?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Hmm ok.
Do you have another keyboard you could test with to see if the same thing happens? It sounds like this may be something on Apples end and there isn't really anything we can do in Maya to override this aside from change the key to something completely different like ctl+f for face mode etc.
All the best,
Sean Heasley
Hi @Anonymous
Thanks for the update!
Yeah unfortunately this seems to be on Apples end and changing the hotkeys seems to be the only solid solution.
All the best,
Sean Heasley
Hi @Anonymous
Oh that's awesome! Thanks for explaining what you did and marking it as the solution and yes hopefully this will help anyone else that may stumble upon this in the future!
All the best,
Sean Heasley
