Export from Maya to Final Cut
How do I export an avi file from Maya to use final cut for editing?
dgorsman
First preference would be to skip the video container and instead render an image sequence, such as PNG.  You want to delay compressing the contents as late as possible in the editing process.
An image sequence export does make sense, but if you just need something quick to cut in you editor you want to "playblast" your work. Right click on the time line and pick "Playblast." Here's more info:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Ani...
