Announcements
Error Messages when Batch Rendering
I am having a few error messages pop up when I go to Batch Render in Maya. They say: dr.Init.mel line 1961: Object “ not found. // and the other says my bounding box is too small. How do I fix these?
sean.heasley
Hi @Anonymous and welcome to the community!
The object not found error has been a weird issue with the modeling toolkit.
The best way to solve this is to delete your settings/preferences.
If you don't wish to do that, you could save the scene, restart Maya, then Import the scene into an empty scene of Maya and that should clear the issue!
Please let me know if this helps or if you need any more information!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I just wanted to check in to see how things were going. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
