Error loading Arnold
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Got this error on one computer
when I try to load mtoa in Plugin Manager
Tried uninstalling Maya, Arnold, installing it again, deleting pref folder, even copying solidangle folder from another computer, no luck
running deadline command: -getrepositoryfilepath submission/Maya/Main/SubmitMayaToDeadline.mel Running submission script "//renderfarm/DeadlineRepository10/submission/Maya/Main/SubmitMayaToDeadline.mel" running deadline command: -GetRepositoryFilepath submission/Maya/Main/Submit.png file -f -new; // Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. // // untitled // commandPort -securityWarning -name commandportDefault; onSetCurrentLayout "Maya Classic"; // AbcExport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08) // AbcImport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08) // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: initializePlugin function failed (sceneAssembly) // // Error: Unable to execute igInitialize.mel. // // Error: Unable to execute xgen.mel. // // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: initializePlugin function failed (Type) // // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: Plug-in, "", was not found on MAYA_PLUG_IN_PATH. // evalDeferred "shaderBallRendererMenuUpdate"; import arnold // Error: Failed to import python module 'arnold' // evalDeferred "shaderBallRendererMenuUpdate"; // Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in "mtoa" has resulted in changes to the scene that may need to be saved. // // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: initializePlugin function failed (mtoa) // updateRendererUI; // Error: file: C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/scripts/xgenUI.mel line 514: Cannot find procedure "MakeXGenHUD". // // Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/others/supportRenderers.mel line 67: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. To prevent this message from being displayed in the future, set the option variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1 //
