// Error: line 1: There are no more commands to redo.
Message 1 of 11
Hi there,
Why I have // Error: line 1: There are no more commands to redo. even if I hit Ctrl + Z ? Is that some memory issue ? Ctrl + Z works just for some time and after several minutes it just stop redo and tells me error.
Thanks for all kind regards.Error line 1 There are no more commands to redo.jpg
Replies (10)
Message 2 of 11
pshwayka
Did you mean "undo"? (That's what ctrl+Z does)
Ususally that means that you've undone everything there is to undo. Also, in your Maya Preferences you can increase the number of "undo's" if you actually are not able to undo as many steps as desired.
Message 3 of 11
J450NP13
Up to the point of where the file was saved.  even if you have infinite selected.
Message 4 of 11
pshwayka
You mean saved and re-opened.
Smiley Wink
Message 5 of 11
J450NP13
Yes....)
Message 6 of 11
Por qué tengo // Error: línea 1: no hay más comandos para rehacer. incluso si presiono Ctrl + Z? tengo el mismo problema incluso con un archivo nuevo y con un par de ordenes realizadas.
Message 7 of 11
juanmontoyalujan
Community Visitor
Community Visitor
Exactly the same thing happens to me, when I try to redo or undo an action even by clicking on "infinity" it appears: // "Error: line 1: There are no more commands to redo. // "
Message 8 of 11
aNASTASIA.kITAEV
Community Visitor
Community Visitor
I have the same problem. I have no caps lock on, I have definitely steps to undo and I did not save the file and opened it again. Still "Error line 1: ..." appears. Yesterday it worked absolutely fine.
Message 9 of 11
turbolet
Community Visitor
Community Visitor
This small Python script helps me to solve issues with Undos, once i face problems i just clean cache and it's works well again
import maya.cmds as cmds
cmds.flushUndo()
Message 10 of 11
lumino_Photoshop
Community Visitor
Community Visitor
I just had the same Issue and i noticed, that I changed accidentally my keyboard from german to english. And because of the flipped y and z on the english keyboard, i always pressed "strg + y", when i actually wanted to press "strg + z". And if you do so, Maya tries to REDO stuff, not to undo. And if nothing is to be REDONE, then this message appears 🙂
Message 11 of 11
emil_schaefer
Community Visitor
Community Visitor
Genius!!! I was going maaad searching for a solution
