Maya Forum
Welcome to Autodeskā€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
// Error: line 1: Cannot find procedure "XgCreateDescriptionEditor".
2 REPLIES 2
1083 Views, 2 Replies
Hello!
I keep having this // Error: line 1: Cannot find procedure "XgCreateDescriptionEditor". I have seen there have already been posts about this and tried following the solutions such as deleting my preferences and doing a clean unninstall and install of maya. I use the 2018 version, but I keep having the same problem.
Can some one help me?
Labels (1)
2 REPLIES 2
Abdulla-Qaladzay
Hello @Anonymous
the mentioned procedure in the error is in this script file :
that solved the problem once
by once I mean after you closed Maya and open it again you have to run the script manually again  to get rid of that error.
try it, if that worked let me know, I probably able to find a solution to it
beto.lujan
Sigue sin funcionar... šŸ˜ž
Technology Administrators
