Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Edge selection constraint by Lenght Maya doesnt keep your min and max value Bug?
1 REPLY 1
Kranos_Orphydian
350 Views, 1 Reply
this feature might be very usefull for removing unnecessary edges  when you simplify your model. It is founf under Select menu > Use constraints > Geometry.  However soon as I type in a value in the min and max fields Maya is chnaging them. Also  the Slider seem to be bugged as well. It jumps from one place to another.  Anyone can replicate this isue ?
1 REPLY 1
I have the same issue using Maya 2019.2.
Is there a way to fix it for Maya 2019.2?
Also, I'm wondering if it is fixed for a newer version of Maya? Maya 2021, for example?
UPD: I just tried to use the following script command and seems like it works properly although the Selection Constraint UI is continuing to show incorrect data.
polySelectConstraint -m 3 -t 0x8000 -l on -lb 0.1 2.00;
