Does Autodesk Maya work with touch screen like surface studio for rotate objects ?
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
Maya does run on surface studios. I personally prefer Cintiqs however because they are more powerful.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the information I provided yesterday help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
