Displacement Map disappearing in graph network
jamoWC3K8
Observer Observer
jamoWC3K8
Observer
Observer
When I plug in a displacement map to a AIstandard surface shader it disappears from the graph network as soon as I leave that particular texture.  I've added it back again and again and restarted Maya (2022), but each time I get the same result - it disappears from the graph network.
I can see in the property editor that the the displacement map is still there, but it doesn't show in the graph network? Does anyone else experience this issue?
SophieStudent
Hi I am having the exact same issue.  🤔   Am asking around and will get back if i get to fix it but maybe you did fix it? 🙏 Pls post if you did.  Thanks
Christoph_Schaedl
Are you on the latest Maya 2022.4 version?
And MtoA 5.3.4.1
https://linktr.ee/cg_oglu
SophieStudent
Hi No-23- but I fixed the issue by pressing “p” to cement the chuffin nodes where they should be 🙂
