CPU render and performance issues.
HI
In the past few days i have working on a project with n particles and rigs involved...I have been facing
1) performance issue---maya has an 'on  off 'delayed opening into an empty scene. And the performance is also                                                      unpredictable.
                                           I have reset preferences...did a fresh reinstall...nothing works.
                                           Its in completely updated 2020 version.
2) CPU rendering-----I have been trying to arnold render particles with cpu render sequence.
                                       It does 99% of first frame in sequence and freezes maya. I have to force out of maya.
                                        It render normally with render current frame. But sequence it freezes.
                                        I have  turned off  autothread in render settings. But to no use.
patrick.schock
Autodesk Support
Autodesk Support
Hello @Anonymous!
Thanks for posting this question. Regarding the Rendering issues, can you please enable the Arnold Log File in Maya and send it to me: How to get an Arnold .log file in Maya
Regarding the performance issues, can you please try to Disable Cached Playback in Maya:
Looking forward to your feedback, if Disabling Cached Playback helps to solve the performance issues.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Hi
I had disabled cached playback but it didn't work.
Regarding rendering issues i changed evaluation mode to parallel and rendering engine to direct DX 11....It worked for now.
Thank you for your reply.
