convert multiple instances to object
Message 1 of 15
I have a scene composed of multiple instances that make up a complete object (say repeating sections of a train carriage or seats) after finishing the modelling I now have the complete object which I need without any instance on it.
if I select all the objects and do modify-> convert instance to object, various parts of this actually disappear,
if I duplicate them the same thing happen, same thing if I export to obj.
the only way is to export to fbx but that destroys the materials.
is there an actual way to retain and convert all instances of a geometry as a separate object without tedious manual processing? maybe some script?
thanks in advance for any pointers.
Replies (14)
Message 2 of 15
sean.heasley
Hi @Anonymous
Have you tried going to Mesh->Combine?
This will combine everything into one object and whenever you need to separate them again you can do Mesh->Seperate.
Please let me know if this helps or if you need any more assistance!
Message 3 of 15
thanks Sean,
combine has the same effect as the others unfortuantely, one or more of the copies disappears
Message 4 of 15
sean.heasley
Hi @Anonymous
Hmm ok.
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Message 5 of 15
@sean.heasley that's a bit tricky but here's some quick steps to reproduce: it seems to happen with instanced groups
so
create a cube and group it,
duplicate special (instance) the group a couple of times,
select all and try combine or any other method.
on my end they just vanish except one
Message 6 of 15
darioOrtisi
Have you deleted all Histroy and/or deletd all constraint after deleted histroy?. This happened to me.
Message 7 of 15
@darioOrtisi seems to happen both with or without history
Message 8 of 15
mspeer
Hi!
If you group the objects and instance the whole group not only the mesh/shape will be instanced, but the direct transform node too (with the identical UUID) making it impossible to distinguish between those objects.
There is currently no workaround or solution i can offer.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Message 9 of 15
sean.heasley
Hi @Anonymous
Thanks for the repro steps!
Like @mspeer said, this looks like an issue with Maya and I've logged it with our dev team so they can work on a fix for a the future.
Message 10 of 15
thanks  a lot  @mspeer and @sean.heasley for logging in the issue, fingers crossed it'll get sorted soon enough.
in the mean time I happened on a workaround with this code, credit goes to lesterbanks
its fairly slow on large scenes and I'm losing shaders on some pieces so would be nice to have an actual solution implemented by autodesk.
# Python code
import maya.cmds as mc
import maya.OpenMaya as om
def getInstances():
    instances = []
    iterDag = om.MItDag(om.MItDag.kBreadthFirst)
    while not iterDag.isDone():
        instanced = om.MItDag.isInstanced(iterDag)
        if instanced:
            instances.append(iterDag.fullPathName())
        iterDag.next()
    return instances
def uninstance():
    instances = getInstances()
    while len(instances):
        parent = mc.listRelatives(instances[0], parent=True)[0]
        mc.duplicate(parent, renameChildren=True)
        mc.delete(parent)
uninstance()
Message 11 of 15
camrynCG68D
Community Visitor
Community Visitor
The way I've gotten around this is by exporting as an FBX and reimporting into the scene. This works with Maya LT as well as regular Maya -- in the full version there should be an option in the export settings under Geometry to Preserve Instances.
I need them as OBJs to import into another software that doesn't accept FBX, and so this work around helped me.
Message 12 of 15
sdouvilleAATP5
Community Visitor
Community Visitor
That code is gold. Thank you
Message 13 of 15
Gillaria
I just want to say that the problem has not yet been solved, despite the fact that 5 years have passed.
Yeah, Autodesk is famous for solving problems in its products.
Many thanks to @Anonymous, the script works well.
Message 14 of 15
sktvete
Almost 6 now, @Sean Heasley
Message 15 of 15
jonathan.beviere
Community Visitor
Community Visitor
Select all the instances
In Modeling Menu Bar :
Modify > Convert > Instance to Object
