Combining Multiple Textures Into One
Hey Everyone,
I'm new to Maya, and I’m running into issues when combining textures together.
I purchased a 3D model that I plan to import into a 2D animation software called Creature. This software converts 3D models into 2D meshes to be used in a 2D setting. In order to allow Creature to import 3D models, they must be combined into one single mesh, in the form of an .obj file, along with all textures being combined into one atlas image.
After about 10 hours of work yesterday, I finally figured out how to load the project file into Maya, getting the textures to load. Then combining all objects into one was pretty straight forward, but now I’m combining the textures into one, and I’m not exactly sure how to do so.
I tried the automatic mapping UV wrap tool to get all of the model’s faces into a single UV, but I can't seem to merge the textures together to fit the newly laid out UV map.
If anyone could offer some insight on what I’m doing incorrectly, and how I should be going about doing this, it’d be very greatly appreciated.
Thanks a lot and I very much look forward to hearing from everyone.
Hey Everyone,
I purchased a 3D model that I plan to import into a 2D animation software called Creature. This software converts 3D models into 2D meshes to be used in a 2D setting. In order to allow Creature to import 3D models, they must be combined into one single mesh, in the from of an .obj file, along with all textures being combined into one atlas image.
sean.heasley
Hi @Anonymous and welcome to the community!
The easiest way to do this would be to make the texture in a program like Photoshop so you can easily layer everything on top of the UVs.
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
I should be able to post a few screenshots/video on how to properly do this!
sean.heasley
I can make a quick video for you showing how to go about this Smiley Happy!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
