Announcements
Color management Missing Linear Color space
Hi, I have autodesk 2016 maya for windows x64. In my Color management color space, i have everything except "Linear Rec." "Linear sRGB" or "Linear." is there a way to install it in my maya? i do not know why i am missing color management Linear. In my 2013 mac maya 2013, it is already inside color management color space, "Linear sRGB or Linear Rec. 709. Thank you
sean.heasley
Hi @Anonymous and welcome to the community!
It's possible these are change that happened from 2013 to 2016.
I'm looking right now and while I don't see the options you are looking for, there is "scene-Linear Rec and SRGB".
Are you not seeing these?
If not, please make sure your Maya is up to date and you may want to try deleting your settings/preferences
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi, I want to let you know that have solved the problem. installing the extension 2 have fix the problem. THank you
sean.heasley
Hi @Anonymous
Awesome! Glad you're back up and running Smiley Happy!
