choose what to save into undo queue
batarg
batarg
everybody knows that issue with memory leek while you paint skinning heavy model...
after 10 mins your memory will be overwhelmed with undo history...
is it possible to control what types of events should stored in undo queue?
currently `flushUndo` solving that issue, but you can also loose other events too
hamsterHamster
You'd possibly want to switch your undoQueue from Infinite back to at least the default 50 steps, more or less, depending on how much your comp can handle. Wouldn't that be an option?
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
batarg
thank you for reply, but it's not good too...  better to flush whenever you need, rather than keep short history list, when you are not skinning
