Announcements
Changing channel values with Middle Mouse Button click + drag suddenly not working
christineZo
christineZo
Hello!
I just suddenly encountered this issue. When I highlight any of the channel values in the channel box and drag in the viewport, it doesn't work as expected -or at all really. I have to keep dragging repeatedly over my viewport and even then it only moves in weird increments. I posted a video of the issue.
I've tried:
-Restarting Maya
- Resetting the channel box settings
-Making sure Step Snap in move, scale and rotate tool settings are off
-Deleting my User Prefs
-Making sure Animation Evaluation mode is set to DG and not Parallel
And at this point I don't know what on earth is happening. I use the MMB Drag a lot when working so if someone could please help me I'd be extremely grateful.
patrick.schock
Autodesk Support
Autodesk Support
Hi @christineZo,
thanks for your post! I just tested the behavior in Maya 2022, and I see no problems when dragging with MMB and one channel field selected in order to rotate, scale or translate.
However, I found out that the direction of mouse movement has an effect. If I do not move the mouse in the direction of the selected axis when controlling the translation, nothing happens. It is the same with rotation and scaling. Could this be a reason for the problem?
Which type of mouse are you using? A "real" mouse or a Wacom pen? Maybe using another mouse could help for a test if the behavior is mouse-related.
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
christineZo
Thank you SO much Patrick!!! You're right, it had nothing to do with Maya at all and everything to do with the Wacom pen I was using (plugging a "real" mouse like you suggested showed that) Unfortunately I'm heavily reliant on a Wacom pen so I rolled back my pen driver to a previous version (6.3.43-3) since I'd never had this issue before the latest driver update (6.3.44-1) in August and it seems to have fixed the problem. I'll also be purchasing a new pen tomorrow just to be safe because I've dropped my pen quite a few times so I may have rattled some things internally..poor pen haha. Many thanks again :)) I'm sure your response will help others in the future!
