Cannot use heat map display in hypergraph.
I am trying to enable the heat map in the hypergraph window so that I can analyse what are the most demanding things in my scene, it is hidden as if it is not available/applicable.
I have attached a screenshot of the menu.
Using Maya 2020
OSB.MAYA
hey,
Did you find a workaround for this issue? I am having the same problem. It was functioning fine a few days ago.
any help wyoul be much appreaciated. thanks!
yann.genty00
Community Visitor
Community Visitor
Hello, have you found a solution since your last message? I have the same problem
