Cannot Edit or Delete Expressions
timdan
timdan
I've searched the forums, and the totality of the internet (probably exaggerating), and cannot find a solution to this. When I try to edit an expression that already exists, nothing happens. When I click to create a new expression, nothing happens. I do not get an error as most other posts of written about where' EEexprEdTextEditor = 0. This is not the case for me. I'm also not on a Mac (currently running Win 10, and Maya 2017 u4).
I need a solution that does not involve deleting my prefs. Can't do it. Too much of our pipeline revolves around those, and I cannot afford to delete them every time something silly like this happens.
Please help.
 - Tim
+ timdan
http://www.timdan.com
timdan
Ok... so I deleted windowPrefs out of the prefs folder, and that did the trick. Didn't have to dump the whole folder, and my expression editor is up and running.
Good talk. 😛
+ timdan
sean.heasley
Hi @timdan
Does this happen in specific scenes or on a new empty scene as well?
Also, if you go to edit an expression does anything appear in the history?
Finally, is updating to update 5 may help but will this throw off your pipeline?
 Edit: Just saw your new post. good talk indeed 😛
timdan
Hey @sean.heasley,
For what it's worth, it happened in new files and old files. What showed up in the history was just the call to load the editor:
expressionEditor EE "[objectShape]" "[value]";
But nothing would actually happen. No errors or anything.
Lastly, I've been considering update 5, but we did some testing with our animators, and they had some serious issues with the sluggishness of playback, so we've been hesitant to move forward with it.
Thanks for following up, though!
+ timdan
