Can't use a symbol font like Wingdings.
Message 1 of 8
Why the heck not!
Get this rather useless error towards solving the problem: "The input text is not available in the current font. Try a different font or writing system."
Replies (7)
Message 2 of 8
sean.heasley
Hi @Anonymous have you tried the Create Type tool? This worked for me and had wingdings typed out and converted to geometry.step 1.png
Message 3 of 8
Of course, That's what causes the error.
Message 4 of 8
sean.heasley
What version of Maya are you on? Im on Maya 2017 update 3 and it works as intended.
Message 5 of 8
Looks like I have Update 2.
If Autodesk would provide documentation that the problem I'm encountering was fixed in Update 3 I'd attempt to update, but I'm not going to hold my breath. Smiley Mad
Message 6 of 8
mspeer
Hi!
I remember that some fonts didn't work with an earlier version of Maya, but with Maya 2017 update 3 they all seem to work.
I'm not sure when that changed, but it would not be the only change missing in documentation if it happened with update 3.
Message 7 of 8
sean.heasley
If you update to update 3 you should be all set. Let me know if you need anything else.
Message 8 of 8
Yes, as I said, some documentation from AD that this issue was a specific problem in update 2 that was fixed in update 3.
