Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't open mb file, always stuck on reduse (Maya 2017)
3 REPLIES 3
vozna.c.s
1036 Views, 3 Replies
Hi! (Maya 2017) The program works fine with all the files. And this file always hangs on this moment. how can i open it i really need it. Or how can I turn off reducing polygons? (esc not working). Can someone help me?
3 REPLIES 3
mspeer
in reply to: vozna.c.s
Hi!
You should have used "delete history".
If the reference file is the problem, then open it and delete history. If it's a object in your main scene the file may be corrupted. (This problem happens mostly when opening a file with history from a previous version of Maya)
Please upload the scene-file.
RickFalck
Agreed. If this is happening when you're trying to load the reference I would first open the reference and clean that up (delete history/ non-deformer history if needed, optimize scene size etc) then try to re-load the reference file in the main scene.
sean.heasley
in reply to: RickFalck
Hi @vozna.c.s
I'm just checking in to see if you need more help with this. Did the suggestions that @mspeer and @RickFalck provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
