Can't manually set a relative path for a simple aiVolume. Help?
futuremotionrecovery
I've set my project, and then tried to set the new path manually. If I deselect and then select it again, the path reverts back to absolute.
Here's a video:
https://streamable.com/smky17
How can I fix this? Remake the volume entirely?
patrick.schock
Autodesk Support
Autodesk Support
Hello @futuremotionrecovery,
can you please check if the solution from here works: aiVolume not allowing relative paths.
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
