Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't change icon label on Maya 2023
4 REPLIES 4
laurasinici
497 Views, 4 Replies
laurasinici
I'm trying to save my tools on a shelf, and then name them. I can do this without problem on Maya 2020, but when I change the icon label on Maya 2023 and click on "save all shelves" to save the changes, the name doesn't change at all. Furthermore, I tried to change the icon, and it works, background transparency and the other options also work. It seems to only ignore the changes on icon label.
4 REPLIES 4
damaggio
in reply to: laurasinici
damaggio
This was fixed in 2023, make sure your version is up to date.
laurasinici
in reply to: damaggio
laurasinici
I uninstalled Maya 2023 and installed Maya 2023.3, now it works fine. Thanks for the help.
damaggio
damaggio
You should pay more attention to the Forums , you’ve been using Maya since 2021 , there’s no reason to to be misinformed, you can learn a ton of things here every day.
laurasinici
laurasinici
Yes, I frequent this forum and another one about maya as well, I'm just not very active here. Thanks for the advice and the help anyway!
