Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Error: line 0: Error reading file
0 REPLIES 0
Message 1 of 1
ad_osc2009
316 Views, 0 Replies
So today I woke up to my rig, meshes, textures, curve controls and materials missing, the only exception being the things that were hidden in the outliner. Yesterday was working just fine but today I have this error message (The first lines are of plugins that still work):
// Error: source "cometMenu.mel" //
// Error: "C:/Users/adosc/Documents/maya/2020/scripts/userSetup.mel" line 2.22: Syntax error //
file -f -new;
// untitled //
doOpenFile ("F:/Documentos F/3D/Volgar/Volgar.mb");
file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "F:/Documentos F/3D/Volgar/Volgar.mb";addRecentFile("F:/Documentos F/3D/Volgar/Volgar.mb", "mayaBinary");
requires "stereoCamera" "10.0";
updateRenderOverride;
requires -nodeType "ngst2SkinLayerData" -dataType "ngst2SkinLayerDataStorage" "ngSkinTools2" "2.0.40";
requires -nodeType "aiOptions" -nodeType "aiAOVDriver" -nodeType "aiAOVFilter" -nodeType "aiSkyDomeLight" "mtoa" "4.0.2";
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: file: C:\Users\adosc\Documents\maya\2020\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\adosc\Documents\maya\2020\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\adosc\Documents\maya\2020\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already. //
import arnold
# Successfully imported python module 'arnold'
import mtoa
# Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
# Successfully registered renderer 'arnold'
// Warning: line 0: swatches file depend node not found, icon discarded: lambert2 //
// Warning: line 0: swatches file depend node not found, icon discarded: lambert4 //
// Warning: line 0: swatches file depend node not found, icon discarded: Clothing_1 //
// Warning: line 0: swatches file depend node not found, icon discarded: hair //
// Warning: line 0: swatches file depend node not found, icon discarded: lambert6 //
// Warning: line 0: swatches file depend node not found, icon discarded: Clothes_2 //
// Warning: line 0: swatches file depend node not found, icon discarded: HairMatAniso //
// Warning: line 0: swatches file depend node not found, icon discarded: eyes22 //
// Warning: line 0: swatches file depend node not found, icon discarded: lambert3 //
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// File read in 1.2 seconds.
// Error: line 0: Error reading file. //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
updateRendererUI;
I found a solution for .ma files but mine is .mb saving as .ma just straight up deletes what's missing
Here is the file if it helps: https://drive.google.com/file/d/1vaxo_F4VhIxk3QerDzocIaj0B9o7FgZq/view?usp=share_link
any help would be appreciated
I tried to upload the file here and this comes out
  • The attachment's volgar.mb content type (application/octet-stream) does not match its file extension and has been removed.
Labels (3)
0 REPLIES 0
