Camera settings to match photo
Hi everyone,
I am trying to build this scene in Maya. (see attached photo)
But to match an image (a screenshot taken from the Netflix TV series, Dark ) in Maya's camera setting, should I input in the camera body's Focal length which I am guessing its 65mm or the lens' focal length, 35mm?
Also, any other tips to match camera settings?
Thank you.
Camera Body used: Alexa 65
Lens used: 35mm ANA / SPHERICAL
*I don't own any of them, just got the information from google*
sean.heasley
Hi @Anonymous and welcome to the community!
I like the reference art!
Generally when trying to model a scene based on an environment it's more important to have the reference lined up right and use perspective matching instead of worrying about the specific camera settings.
All of the effects that are seen by the type of camera and resolution etc. we don't worry about and we focus more on the materials and lighting to match the reference.
While the scene is different, this video gives a good breakdown on using an image and matching it to a camera.
Please let me know if this information helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Thank you for the reference video and advice, it is helpful. But isn't camera settings important as well? If, say, the focal length is different, won't everything, like the distance between each object or objects to the camera be messed up?
damaggio
For the Alexa65 you need to enter the sensor size ,which you have in your image 54.12 X 25.59  enter this number in the Maya camera attributes that is set to mm.
Next use the prime camera lenses from the Alexa website and the camera leans used for the Netflix show if you have that info.
damaggio
Camera Attributes Aperture (mm)....and remember to save your camera presets.
Thanks for the information.
