Bug with Rename Material.
sergeympopov212
sergeympopov212
Hello. A trouble is when you create a new material, assign it on object and then rename it and common material attributes stop working.
Replies (12)
john.paul.giancarlo
yep since is just color it should work, I will report this one , anyways all you need to do to make it work again is to turn on textures in the viewport by hitting the 6 key or directly in the viewport icon.
see image below
Thank you for this
mspeer
Hi!
This is a new bug in Maya 2018.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
damaggio
Is this also present on windows 7?... sounds like a nightmare bug
if you can't name shaders.
mspeer
Hi!
"Is this also present on windows 7?"
Yes.
damaggio
Forgot to ask about other shaders like Vray and Arnold .same thing ?... and that does not happened when textures are controlling the shader?
sergeympopov212
Yes same thing with arnold. I don't test it on v-ray and mantal ray.
damaggio
Okay thanks
mspeer
Hi!
While @john.paul.giancarlo helps only for textured view, saving and re-loading the scene seems to remove the problem completely (until you re-name again)
Was this ever addressed? I am encountering the same problem on the latest update of Maya 2018. I just submitted a bug.
The solution proposed by @john.paul.giancarlo does not work when I rename the material when already in Textured mode. If I rename the material in Textured mode, occasionally the material will work again if I switch to Smooth Shaded mode, and vice versa.
This is a huge problem for my workflow because it my workflow involves naming my materials, haha.
For anyone searching for a practical workaround to this problem:
Pausing, then unpausing the viewport fixes the problem. You still have to do it after every time you rename a material, but it works until they actually fix the bug.
You can put this as a shelf button:
ogs -pause;
ogs -pause;
Thanks for an actual fix! Heart
ogs -pause;
ogs -pause;
Great help Garrett Stevens,
Due to my data down limitations (COVID lockdown) I cannot download the complete new version now. This fix has helped me a lot to continue working with the 2018 version with bug.
For others who do not want to use shelf buttons. In the picture below I have marked the pause/unpause button for the view-port.
