Hello everyone!
I'm been using Maya for 3 years and just today, when I opened a model I was working these days, the perspective viewport looked like a grey layer was over it, I reseted the camera but then I figured out the problem was a blue box in the timeslider, when I delete it all became normal.
At this moment I do not know what that means! But it changes from opacity 50% to 100% in the timeslider and all I have done is modeling and animating using selected keys!
BLUE BOX IN THE TIME SLIDER: OPACITY 50% AND 100% IN DIFERENT FRAMES
AFTER DELETED ALL COLORS COME TO NORMAL.
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
I'm trying to get this to appear on my Maya but I'm not seeing it.
Do you have any idea how it started to appear there?
If not, when you get a chance can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it? If the file is confidential or under NDA please send it to me in a private message instead of posting it here.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Thanks for sending me the file!
The box seems to be appearing because of _Scout_0034:_UNKNOWN_REF_NODE_fosterParent1 in the Outliner.
Simply delete this and the box should disappear but the animation won't be affected.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
