In default lighting in the viewport, when I apply the exact same shader, first to an object I created from polygons, and second to a plant leaf created by converting a plant paint effect object into polygons, the plant leaf shows as all black, while the polygon from scratch shows light and shadow. When rendered, both behave normally but the plant leaf always renders slightly darker? Is there some kind of shader that comes pre-attached to paint effect? What is going on?
