Announcements
batch rotating several pivots ina relative way
HeavyMetalFox
Message 1 of 1
HeavyMetalFox
I have several objects in my scene (around a thousand) and I need to rotate their pivot in 90 degrees in one direction so that the Z axis is pointing forward instead of the X axis.
When I select them, enter pivot mode and rotate them all in 90 degrees, all their pivots are pointing in one direction which is undesired.
How can I select all the objects and rotate their pivots in a relative way to each object by 90 degrees so that the Z axis of each object is pointing forward instead of the X axis.
Replies (0)
