I just installed Autodesk Maya 2017 in my computer, this is win 10 and the program not started. These are the specifications of my computer.
System Information
Time of this report: 4/1/2017, 19:02:40
Machine name: DESKTOP-NH0LFKV
Machine Id: {7288BDA7-46E3-4BB5-A406-2F11DC24B697}
Operating System: Windows 10 Home Single Language 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.170303-1614)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: GL752VW
BIOS: GL752VW.210
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Available OS Memory: 16252MB RAM
Page File: 4069MB used, 15127MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
Here is a video of the problem :
please help me!!
Hi @Anonymous sorry you're having this issue! First I would recommend making sure all your drivers are up to date and if they are then you can try a clean uninstall and reinstall of Maya 2017. If a clean uninstall and reinstall doesn't work this could also be an issue with your Maya profile that doesnt get uninstalled so you can follow these steps!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
I got the exact same problem and I followed your instructions to try to solve the problem, but still it changes nothing. The program pops up for a second and disappears. Before that I tried reinstall maya and even reinstall my system. None can help. I hope you can provide me a solution soon. Thanks.
Weird. Could you try running your PC in safe mode and see if Maya can launch that way? Also be sure to have task manage open and be a little patient because Maya does take some time to launch and be up and running.
All the best,
Sean Heasley
