Asking for quads while creating text
Hi everyone !
I created a text with the following Settings:
Poly
Quads
Count (Count to 1000)
As you can view it on the attached file, I have got faces with more than 4 edges (cleanup mesh).
Is there a way to fix that (without checking triangles) ?
Thank you.
sean.heasley
Hi @Anonymous
Did you create this via the Text tool or did you manually model the text?
A simple way to fix this would be to use the cleanup tool and have it apply to faces with more than 4 sides and hit apply. It won't be the cleanest topology but it will fix the n gon issues.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Hi @sean.heasley
I did it through the text tool.
We could have thought that, choosing quads, Maya would have generated quads and triangles.
For sure it can be fixed with the cleanup process.
I have another question about this object.
It is about adding a bevel.
The job is not so good.
Many things to fix and it costs time !
Many thanks for reply
It Comes from the geometry that has to be fixed before applying the bevel
sean.heasley
Hi @Anonymous
If the clean up tool works and has a few triangles I'm not sure I see the issue. Is there a reason you can't have any triangles on the mesh?
Also, as for the bevel you just need to simply tweak the settings and values of it until you get the desired effect.
If that still doesn't work for you, you can always manually select the edges and bevel that way so you have more control.
Let me know if anything changes!
@sean.heasley
It's not an issue having a few triangles.
The bevel process doesn't not run perfectly on each edge and some have to be fixed manually.
