Announcements
Arnold error: indexed user-data in companion array ...
pretzelking1234
Message 1 of 9
pretzelking1234
It keeps making some of my material map disappear when it worked perfectly in Maya 2020 but not in Maya 2023
Error: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1
*This posts subject title has been edited from "I get this error when trying to render in arnold: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1"
Replies (8)
Message 2 of 9
ayerssj3446
Observer
Observer
Same here
Message 3 of 9
Stephen.Blair
Hi
What versions of Maya and MtoA are you using? What operating system?
Tip: the header of an Arnold log has all those details
What is map1 ? Can you simplify the scene down to just the object that has map1 and upload it?
// Stephen Blair
// Arnold Renderer Support
Message 4 of 9
dalecampbelljrLUC83
I am getting the same type of error....
// Warning: WARNING | /ToiletBase/ToiletBase/ToiletBaseShape: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1'
// Warning: WARNING | /ToiletBase/polySurface2/polySurfaceShape2: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1'
// Warning: WARNING | /ToiletBase/ToiletBase_top/ToiletBase_topShape: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1'
// Warning: WARNING | /ToiletBase/ToiletBaseHandle/ToiletBaseHandleShape: indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1'
Message 5 of 9
aligillies
I get the same error then it crashes,
"indexed user-data in companion array has out-of-bounds indices in map1idxs! (should be less than 0) -- disabling user-data 'map1'"
Message 6 of 9
Pi-errs
same still no answer or fix, its so normal on Autodesk Support for no Premium Customers.
Message 7 of 9
hagen.deloss
Hi all,
@Pi-errs is the error you are encountering the same exact error? Can you copy and paste the exact error being thrown?
From the context of previous posts and some searching, this Arnold error is most likely due to a tool that has been changed within Arnold from the previous version your file was saved in, potentially your UV's are affected, or the root of the issue. Try re-packing your UV's, posting some screenshots with additional details, or opening a support ticket here so someone from the support team can help ya!
Warm regards,
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 8 of 9
antonio_santosCM2FN
Community Visitor
Community Visitor
Hi guys,
To anyone who's facing this issue. "I" (it was my prof. actually who solved it for me)... Simply toggle on/off COLOR TEMPERATURE on your HDRI.
That fixed it for me.
Message 9 of 9
899390107
Thank you. This resolved the problem for me.
