Arnold 5 Shadow Matt Transparency/Opaque issue
Message 1 of 11
Plane remains opaque and projects the Hdri .
Replies (10)
Message 2 of 11
sean.heasley
Hi @Anonymous I followed a long with the tutorial you were following and couldn't recreate your issue.
    I recommend resetting your settings/preferences and seeing if that changes anything.
    Let me know if this helps!
Message 3 of 11
mspeer
Hi!
@Anonymous and @sean.heasley.
There was a problem with Shadow Matte in Arnold 2.0.0 which was resolved in 2.0.0.1:
https://support.solidangle.com/display/A5AFMUG/2.0.0.1
Please reply if this solvers your issue.
With a short test of 2.0.0 i had the same problem only being able to view the texture of the Skydome (the passes still work).
Message 4 of 11
The issue still persist . I think i will have to downgrade to arnold 4 and just wait for the new Arnold service pack . Ive tried many fixes but none work .
Message 5 of 11
Im using MtoA 2.0.0.1
Arnold core 5.0.0.2
So the docs said the issue was fixed , practically apparently not . Not sure whats the matter with this .
Message 6 of 11
Can any of u take a few mins to check and record the results on ure end?
Message 7 of 11
sean.heasley
Hi @Anonymous strange that fix didn't work for you. Can you attach your scene file so I can take a look at it?
Message 8 of 11
Message 9 of 11
sean.heasley
Ah ok. After looking at the scene and talking to a co worker he confirmed that it's a known issue and will be fixed in next mtoa. I'll keep you posted if I find a workaround!
Message 10 of 11
Hope to see what solutions you come up with .
Message 11 of 11
I think im gonna go back to arnold 4 , need to get these shots going , hope this gets fixed soon .
