aistandardvolume when set to blackbody emission does not work
Bryant4863
Message 1 of 9
Bryant4863
I was trying to create a smoke and fire simulation with bifrost aero and when aistandardvolume emission was set to black body this is what arnold renders. its a weird ring of light around the perimeter of the simulation, i tried messing with various settings but i have gotten nowhere.
Replies (8)
Message 2 of 9
sean.heasley
Hi @Bryant4863
Is there a light in your scene?
Also, if you change the emission settings around does that affect it at all?
Message 3 of 9
mspeer
Hi!
This looks like clipping (values too high at center).
Message 4 of 9
sean.heasley
Hi @Bryant4863
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 5 of 9
Bryant4863
hello, sorry for late reply, yes i am still having the issue i have messed with the settings for emission and when I clear the channel parameter it kinda fixes it but it has no emission, just smoke. I have a screenshot of the attributes before touching anything except for the blackbody selection
Message 6 of 9
sean.heasley
Hi @Bryant4863
Can you check the clipping values like @mspeer  suggested?
Message 7 of 9
mspeer
Hi!
Usually Maya attributes operate in the range from "0" to "1".
The values used and generated (and emitted by the bifrost emitter if using default values) are way to high here.
So use an other mode or channel, or simply reduce attribute "Temperature" which acts as multiplier (try "0.001").
Message 8 of 9
Bryant4863
okay, where would i find this value at?
Message 9 of 9
Bryant4863
okay, so i found the solution and it was exactly as you said thank you very much 🙂
