About instance duplicating & combining
I have a model made of similar objects.
I made the first one and then duplicated it as parent to instances (Ctrl+Shift+D).
I get one common UV map.
When I combine everything into one model, the UV map turns darker (dark blue) because it's a stack of the various similar UV maps.
It's not an issue if I don't move the shells.
But I would like to understand why it is so.
Thanks.
mspeer
Hi!
You already declared it.
If you merge them there are no more instances, but one single object with individual faces.
