I'm trying to use the 3D paint tool on a model with UDIMs (4 tiles) to create ID map to use in substance painter and it's not working, here is what I try:
Is there a solution to this problem ? does 3D paint tool support multi-tile paint ?
Thanks a lot.
Solved by Christoph_Schaedl. Go to Solution.
There is no way to paint UDIMs in maya. You need to use Mari, Mudbox, or 3DCoat.
To create mat IDs in Painter you just need to assign different shaders to your highres.
And bake an ID pass in Painter.
