2024.2 Maya - no highlight on multiple objects selection
yndusWMVNJ
yndusWMVNJ
So, i have this weird problem with selection of multiple objects that only truly highlight the last selected object ( in green ) while other objects in the selection remain gray. This wasn't like this by default - default would actually select all the objects and will emphasize the last one the most but you can still see other objects slightly less highlighted but - highlighted. This worked perfectly fine till yesterday and for some reason it's not anymore - ( it might be that I pressed something while working and I didn't noticed it till later on - but, what ?)
any ideas on how to fix this issue ? thank you.
asafbenzur
I encountered the same issue. Deleting the prefs folder solved the issue for me
syracoj
if you go into Windows > Settings & Preferences > Color Settings
Then go to the Active tab and expand the objects, what is your Polygon surfaces color set to?
If you still hvae your prefs, could you zip them up and forward to us please?
