Hey Guys,
New here and trying to find some answers about interactive grooming in Maya.
So Is it even possible to duplicate a description? For instance, you setup a right brow description and you'd like to duplicate it and mirror it.
Any info. is greatly appreciated.
Thanks!
Solved by Michael_Todd. Go to Solution.
Descriptions can be duplicated but Mirroring is not yet something that can be done automatically. You can export the description as a cache and then import that cache and scale it by -1 in X and freeze the transforms and make a new description from the curves using the the curve to spline modiifer.
The grooming brushes all have options to reflect across a given axis as well, so you could groom one eyebrow whilst having it mirrored automatically.
I see, so you can't really duplicate it withing the grooming stack. I guess this works as a work around, let me give it a try.
Thanks!
You can duplicate descriptions yes, but this will create a new copy of the description. Mirroring across the axis is not yet implemented.
Cheers
I see, it's in the Descriptions -> Transfer menu
Seems to be a good way to create a stray layer.
