Hello!
I got a problem with Maya nParticles. I have two emitting objects in one scene and the second one is colliding with the colliders of the first emitter. Is it normal or do I have to change some attributes to make the secont emitter work without collision?
Best regards,
Susanne
Solved by mspeer. Go to Solution.
Hi!
The nDynamics work by using a Nucleus solver.
All objects connected to the same Nucleus solver do interact with each other by default.
Adjust the dynamic options for your object or simply connect to a new Nucleus solver.
(Choose "Create New Solver" for Solver when creating the second Emitter.)
