Xgen spewing thousands of errors regarding vertex float xgClumpingWeight
Message 1 of 22
I've inherited a nice scene I'm trying to render, it was generated in Maya 2016 using Xgen.
I'm currently in 2018.3 trying to re-render the scene and on completion of the render I get thousands of these errors, locking up Maya for a few minutes:
// Warning: line 1: XGen(2):  CV attribute length doesnt match number of cvs in primitive [vertex float xgClumpingWeight]  //
I have multiple collections, descriptions, etc. The Xgen folder exists and has data in it. But the error isn't very specific and I can't find a way to suppress it (the render appears to be correct) And ideas on how to solve this would be great.
Replies (21)
Message 2 of 22
sean.heasley
Hi @Anonymous
This could be related to changes that have occurred with Xgen since 2016 and therefore why you're seeing the errors.
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Message 3 of 22
I prefer a blind FTP, I cannot post this publicly. (It's not NDA but I cannot make it available to others by posting a link here.)
This scene has quite a few dependencies where many plugins were loaded and I cannot remove them since I do not have these plugins here. Beware!
It will also complain about some Pfx Hair as an added bonus but not gotten to that yet....
Message 4 of 22
sean.heasley
Hi @Anonymous
If you don't wish to post it publicly you can send it to me directly in a private message.
Message 5 of 22
sean.heasley
Hi @Anonymous
Thanks for sending me the scene file!
I downloaded a trial of Renderman to try and see if the same XGen errors would appear but unfortunately I'm only getting fatal errors on render which I believe is due to the pre and post render MEL you are using.
(XgPreRendering;; pgYetiVRayPreRender)
and
(pgYetiVRayPostRender)
That said, I'd like to get a bit more information as I'm going to pass this along to our devs to see if they can assist further.
Is the scene rendering normally and just showing the errors or is the render not completing due to the error?
Also by chance have you tried rendering this in 2016 where you got the file from and if so does the error still appear?
Message 6 of 22
The pre and post mel should be removed. I forgot he had those in there. My mistake. They're Vray and the scene doesn't use it.
The errors in 2018 are Maya errors, it doesn't matter if I use RenderMan or not. I have only been rendering in 2018 because RenderMan 22 does not/will not support Maya 2016.
The errors happen after the render completes, Maya will lock up and print errors for a few minutes and then respond again.
Message 7 of 22
sean.heasley
Hi @Anonymous
Ah ok my mistake. I dropped the mel code and just did a straight render with Arnold (without fixing the shader connections) and surprisingly didn't get a single Xgen error.
My script editor:
Exporting XGen Collections...Done.
# Warning: node entry "mayaFluid" is deprecated, use "MayaFluid" #
# Warning: [mtoa] [translator polymesh] ShadingGroup m_shoeMetal2SG MPlug not found #
# Warning: node entry "hair" is deprecated, and may be removed in the future #
# Warning: [mtoa] [translator polymesh] ShadingGroup m_purseKeyChainSnowSG MPlug not found #
# Warning: [mtoa] [translator polymesh] ShadingGroup m_shoeLacesSG1 MPlug not found #
# Warning: [mtoa] [translator polymesh] ShadingGroup alLayer7SG has no surfaceShader input #
# Warning: hatDotShape: could not read ARRAY parameter "time_samples" #
# Warning: [mtoa] [translator polymesh] ShadingGroup alLayer6SG has no surfaceShader input #
# Warning: furVest2Shape: could not read ARRAY parameter "time_samples" #
# Warning: [mtoa] [translator polymesh] ShadingGroup alLayer12SG has no surfaceShader input #
# Warning: hatFluff1Shape: could not read ARRAY parameter "time_samples" #
# Warning: There are no lights in the scene. #
// Warning: [curves] hairRedone:pfxHairShape1: missing num_points parameter (empty curves?) //
I'm going to do a bit more testing and properly set up the shaders to see if that changes anything.
Message 8 of 22
Ok, that's odd. I'm currently on Maya 2018.3
If there's anything you need like ENV variables or similar, let me know. Is it possible the errors being printed by Maya are from our own procedural? We separate our errors, ours print as [rfm] in our own debug settings.
Message 9 of 22
sean.heasley
Hi @Anonymous
It's definitely possible its from your own procedural.
That said if you can let me know what ENV variables you have that would be great because I'm testing this on pretty much vanilla 2018.3 so it wouldn't surprise me if there's a settings/plug-in etc that could be causing this on your end.
Message 10 of 22
Here it is:
MAYA_MODULE_PATH: C:/Program Files/Common Files/Autodesk Shared/Modules/maya;C:/Program Files/Autodesk/Maya2018/modules;C:/Users/hackett/Documents/maya/2018/modules;C:/Users/hackett/Documents/maya/modules;C:/Program Files/Common Files/Autodesk Shared/Modules/maya/2018
MAYA_CONTENT_PATH: C:/Program Files/Autodesk/Maya2018/Examples;C:/Program Files/Autodesk/Bifrost/Maya2018/examples/Bifrost_Fluids;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/MASH Examples;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/Smart Presets
FBX_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/
ATF_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/
SYSTEMROOT: C:\WINDOWS
QT_MAC_DONT_OVERRIDE_CTRL_LMB: 1
COMSPEC: C:\WINDOWS\system32\cmd.exe
PYTHONPATH: C:/ProgramData/Redshift/Plugins/Maya/Common/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/scripts;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/boss;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/presets;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/scripts;C:/Program Files/Pixar/RenderManForMaya-22.0b7/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/scripts
MAYA_PRESET_PATH: ;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/presets;C:/Program Files/Autodesk/Bifrost/Maya2018/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/presets;C:/Program Files/Pixar/RenderManForMaya-22.0b7/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/presets;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/presets
XBMLANGPATH: C:/ProgramData/Redshift/Plugins/Maya/Common/icons;C:/Users/hackett/Documents/maya/2018/prefs/icons;C:/Users/hackett/Documents/maya/prefs/icons;C:/ProgramData/Autodesk/maya/2018;C:/Program Files/Autodesk/Maya2018/icons;C:/Program Files/Autodesk/Maya2018/app-defaults;C:/Program Files/Autodesk/Maya2018/icons/paintEffects;C:/Program Files/Autodesk/Maya2018/icons/fluidEffects;C:/Program Files/Autodesk/Maya2018/icons/hair;C:/Program Files/Autodesk/Maya2018/icons/cloth;C:/Program Files/Autodesk/Maya2018/icons/live;C:/Program Files/Autodesk/Maya2018/icons/fur;C:/Program Files/Autodesk/Maya2018/icons/muscle;C:/Program Files/Autodesk/Maya2018/icons/turtle;C:/Program Files/Autodesk/Maya2018/icons/FBX;C:/Program Files/Autodesk/Maya2018/icons/mayaHIK;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/icons;C:/Program Files/Autodesk/Bifrost/Maya2018/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/icons;C:/Program Files/Pixar/RenderManForMaya-22.0b7/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/icons;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/icons
HOMEDRIVE: u:
SYSTEMDRIVE: C:
PROCESSOR_LEVEL: 6
OS: Windows_NT
CV_INSTANCE001: C:\Program Files\Commvault\ContentStore\Base
USER: hackett
RMSTREE: C:\Program Files\Pixar\RenderManForMaya-21.7\
MAYA_SCRIPT_BASE: C:/Program Files/Autodesk/Maya2018
TEMP: C:\Users\hackett\AppData\Local\Temp
COMMONPROGRAMFILES(X86): C:\Program Files (x86)\Common Files
MAYA_LOCATION: C:/Program Files/Autodesk/Maya2018
HOMEPATH: \
QT_HARFBUZZ: old
MAYA_MODULE_UI_WORKSPACE_PATH: ;C:/Program Files/Autodesk/Bifrost/Maya2018/resources/workspaces
HOMESHARE: \\sambaserver\hackett
SESSIONNAME: Console
MAYA_FBX_PLUGIN_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/plug-ins
TMPDIR: C:/Users/hackett/AppData/Local/Temp
MAYA_PLUG_IN_PATH: C:/ProgramData/Redshift/Plugins/Maya/2016/nt-x86-64;C:/Users/hackett/Documents/maya/2018/plug-ins;C:/Users/hackett/Documents/maya/plug-ins;C:/Program Files/Autodesk/Maya2018/bin/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/plug-ins;C:/Program Files/Autodesk/Bifrost/Maya2018/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/plug-ins;C:/Program Files/Pixar/RenderManForMaya-22.0b7/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/plug-ins;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/plug-ins;C:/Program Files/Pixar/RenderManForMaya-22.0b7/plugins
WF_IMF_CIN_CORRECTION: both
XGEN_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/
TMP: C:\Users\hackett\AppData\Local\Temp
COMPUTERNAME: SINISTER
COMMONPROGRAMFILES: C:\Program Files\Common Files
SUBSTANCES_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/substance/substances
HOME: C:/Users/hackett/Documents
MASH_LOCATION: C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/
BIFROST_LOCATION: C:/Program Files/Autodesk/Bifrost/Maya2018/
PROCESSOR_ARCHITECTURE: AMD64
ALLUSERSPROFILE: C:\ProgramData
USERDOMAIN_ROAMINGPROFILE: PIXARAD
MDL_USER_PATH: C:\Users\hackett\Documents\mdl\
PROGRAMW6432: C:\Program Files
USERNAME: hackett
WF_IMF_CIN_WHITE_POINT: 685
RMANTREE: C:\Program Files\Pixar\RenderManProServer-22.0b7\
ONEDRIVE: C:\Users\hackett\OneDrive
XGEN_ROOT: C:/Users/hackett/Documents/maya/projects/default/xgen
USERDNSDOMAIN: AD.PIXAR.COM
MAYA_RENDER_DESC_PATH: C:\Program Files\Pixar\RenderManForMaya-22.0b7\etc
PATHEXT: .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
WINDIR: C:\WINDOWS
APPDATA: C:\Users\hackett\AppData\Roaming
NUMBER_OF_PROCESSORS: 44
MAYA_REVERSE_FILEFORMAT_EXT: 1
PUBLIC: C:\Users\Public
USERPROFILE: C:\Users\hackett
PSMODULEPATH: C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules\
REDSHIFT_COMMON_ROOT: C:/ProgramData/Redshift/Plugins/Maya/Common
AUTOLOADER_LAPS: 10
PROCESSOR_IDENTIFIER: Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
PROCESSOR_REVISION: 4f01
PATH: C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/ATF;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/ATF/alias;C:/Program Files/Autodesk/Maya2018/bin/Cg;C:/Program Files/Autodesk/Maya2018/bin;C:/Program Files (x86)/Common Files/Oracle/Java/javapath;C:/Program Files (x86)/Intel/iCLS Client/;C:/Program Files/Intel/iCLS Client/;C:/ProgramData/Oracle/Java/javapath;C:/Python27/;C:/Python27/Scripts;C:/WINDOWS/system32;C:/WINDOWS;C:/WINDOWS/System32/Wbem;C:/WINDOWS/System32/WindowsPowerShell/v1.0/;C:/Program Files/Perforce;E:/Perforce/hackett-sinister/build/pymk;C:/Python27/Scripts/;C:/Program Files/doxygen/bin;C:/Program Files/rv-win64-x86-64-6.2.4/bin;C:/Program Files (x86)/Intel/Intel(R) Management Engine Components/DAL;C:/Program Files/Intel/Intel(R) Management Engine Components/DAL;C:/Program Files (x86)/Intel/Intel(R) Management Engine Components/IPT;C:/Program Files/Intel/Intel(R) Management Engine Components/IPT;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/bin;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/lib;C:/Program Files/Autodesk/Maya2018/bin;C:/Program Files/NVIDIA Corporation/mentalray 3.14 for Maya 2017/bin;C:/Program Files/PuTTY/;C:/Program Files/Google/Google Apps Sync/;C:/Program Files/Google/Google Apps Migration/;C:/Program Files/Pixar/RenderManProServer-22.0b7/bin/;C:/Users/hackett/AppData/Local/Microsoft/WindowsApps;;C:/ProgramData/Redshift/Plugins/Maya/2016/nt-x86-64;C:/Program Files/Autodesk/Bifrost/Maya2018/bin;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/bin;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/bin;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/bin
MAYA_SCRIPT_PATH: C:/Users/hackett/Documents/maya/projects/default/scripts;C:/ProgramData/Redshift/Plugins/Maya/Common/scripts;C:/Users/hackett/Documents/maya/2018/scripts;C:/Users/hackett/Documents/maya/scripts;C:/Users/hackett/Documents/maya/2018/presets;C:/Users/hackett/Documents/maya/2018/prefs/shelves;C:/Users/hackett/Documents/maya/2018/prefs/markingMenus;C:/Users/hackett/Documents/maya/2018/prefs/scripts;C:/Program Files/Autodesk/Maya2018/scripts;C:/Program Files/Autodesk/Maya2018/scripts/startup;C:/Program Files/Autodesk/Maya2018/scripts/shelves;C:/Program Files/Autodesk/Maya2018/scripts/others;C:/Program Files/Autodesk/Maya2018/scripts/AETemplates;C:/Program Files/Autodesk/Maya2018/scripts/unsupported;C:/Program Files/Autodesk/Maya2018/scripts/paintEffects;C:/Program Files/Autodesk/Maya2018/scripts/fluidEffects;C:/Program Files/Autodesk/Maya2018/scripts/hair;C:/Program Files/Autodesk/Maya2018/scripts/cloth;C:/Program Files/Autodesk/Maya2018/scripts/live;C:/Program Files/Autodesk/Maya2018/scripts/fur;C:/Program Files/Autodesk/Maya2018/scripts/muscle;C:/Program Files/Autodesk/Maya2018/scripts/turtle;C:/Program Files/Autodesk/Maya2018/scripts/FBX;C:/Program Files/Autodesk/Maya2018/scripts/mayaHIK;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/scripts;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/boss;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/presets;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/scripts;C:/Program Files/Pixar/RenderManForMaya-22.0b7/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/scripts;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/scripts
LOCALAPPDATA: C:\Users\hackett\AppData\Local
RFMTREE: C:\Program Files\Pixar\RenderManForMaya-22.0b7\
PROGRAMDATA: C:\ProgramData
MDL_SYSTEM_PATH: C:\ProgramData\NVIDIA Corporation\mdl\
FP_NO_HOST_CHECK: NO
ADSK_CLM_WPAD_PROXY_CHECK: FALSE
MAYA_APP_DIR: C:/Users/hackett/Documents/maya
MAYA_PLUG_IN_RESOURCE_PATH: ;C:/Program Files/Autodesk/Maya2018/plug-ins/ATF/resources;C:/Program Files/Autodesk/Bifrost/Maya2018/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/MASH/resources;C:/Program Files/Pixar/RenderManForMaya-22.0b7/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/fbx/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/camd/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/substance/resources;C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/resources
COMMONPROGRAMW6432: C:\Program Files\Common Files
KATANA_RESOURCES: C:\Program Files\Pixar\RenderManForKatana-22.0b7-katana2.6\plugins\Resources\PRMan22
Message 11 of 22
If rendering with RenderMan 21.7, you can set the Integrator to PxrOcclusion, it will ignore a lot of things like missing lights, etc and reduce the spew of other errors.
I also prevent all other renderers from loading. This means everything except RenderMan and Maya Software. Attached the result of a render as an image. The printout of errors is unending. Somewhere we're not getting the right data for the clumping.
Including about 25% of the error output too. The rfm errors are related to the Paintfx Hair not being drawn correctly.
Message 12 of 22
sean.heasley
Hi @Anonymous
Thanks for sharing your env variables.
I added them to mine and tried to render again and got the exact same results so this leads me to believe that this may be something with your own procedurals printing the error.
That said, you said the render is working properly right and it's more that this error is just appearing for seemingly no reason right?
Message 13 of 22
sean.heasley
Hi @Anonymous
Just saw your post right after I posted my response.
Out of curiosity, if you render with Arnold do the same errors appear?
Message 14 of 22
I don't get those specific errors for Xgen, so the question becomes what we're missing in our own procedural that's causing this, do you have a link to the correct-relating API? We'd like to solve that.
The paintfx hair errors is there but mercifully brief.
Message 15 of 22
sean.heasley
Hi @Anonymous
I don't personally have any links for that but I'm going to reach out to our devs and higher support right now with this and see if we can get that information for you.
Message 16 of 22
Thanks for checking, can't seem to find the obvious error on this end.
Message 17 of 22
sean.heasley
Hi @Anonymous
Thanks for the update!
Just so you know the developers and QA are looking into this and I'll get back to you as soon as I have more information!
Message 18 of 22
Random Xgen question, should be a quick answer: The interactive Xgen does not seem to output IDs per curve like the original did (id_XP), does interactive Xgen not generate IDs? If it does, then how do you export them? We may have to do this our self but we wanted to be sure.
Message 19 of 22
sean.heasley
Hi @Anonymous
I passed this along to one of our higher support techs that work with Pixar regularly so I should be hearing back from them soon!
Message 20 of 22
sean.heasley
Hi @Anonymous
I'm still waiting on our QA team about your initial issue.
However for your question about IDs we have documentation on the API here that should help you!
