Message 1 of 12
05:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to export a description to from one mesh to another. The mesh shapes are identical but the vert order is different. When the groom is imported onto the new geometry the clumping changes, as if the "point randomness" value or a seed value somewhere on the clump modifier changed. This wrecks the groom. Is this a bug and is there a workaround?
To recreate: create a new groom on a sphere. Add a clump modifier. Export the description. Duplicate the sphere and insert a few spans. Import the description onto the duplicated sphere. Compare grooms. The clumps on duplicated geometry should have shifted dramatically where the new spans were added.
thanks
