un-instance xgen archive instances or convert to polygon
Hi all,
  I am making a bird with feathers using xgen's archive instance option.
Now I followed a previous thread and exported the description as a MEL.
Now when I import the MEL, it is a group of instanced feathers. I am unable to group them or export the whole thing as an obj. It just gets maya stuck !
I want to manually edit the feathers..so I have to get the feathers to be un-instanced (make unique).
Do you have a solution to uninstance xgen archive instances?
Already tried : Modify convert instance to object - this one deleted all feathers except one!
                       Export alembic - gives double surfaced /nonmanifold geometry and messed up UVs
                       Export other geo cache - maya stuck !
                       Export obj - maya stuck !
                       Combine all feathers - maya stuck !
mspeer
Hi!
"Modify convert instance to object - this one deleted all feathers except one!"
You need to select all individual instance transforms (white + green selection shown).
OBJ export works here but may need some time (several minutes or even an hour) dependent on polycount, which is usual very high for a lot of instances.
Thanks. But I did try both.
Just one feather was given as the result in any if those convert to object option.
And converting to obj was taking more than 4 hours or Maya got stuck, so I had to kill.
I am still looking for a solution 😞
mspeer
Hi!
Please upload a scene-file (maybe with just 5 instances).
Also please post a screenshot of your selection (Oultiner + Viewport) before using "Instance to Object".
