Passive Collider Not Working (Cannot view rigid thickness)
b00375640
b00375640
I am trying to add a boiling water effect to a pot on a stove. I used fill object and created a new nucleus. I then made the pot a passive collider (rigid).
I have changed the solver display to collision thickness and no solver comes up, therefore I cannot see how I should be adjusting my thickness.
Now the water particles slowly fall through the pot. Any ideas on how to fix this?
Also, I would like to change the starting position of my water particles. Right now they start in the air and fall into the pot. Is there a way I can make them start in the pot from frame 1?
Thank you.
hamsterHamster
Some things to check:
Make sure you have created nCloth > CreatePassiveCollider, and in the nRigid shape set Thickness at least to 0.001 to visualize it.
To increase simulation accuracy i.e. lessen the escaping particles, increase Substeps and MaxCollisionIterations in the Nucleus node SolverAttributes.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
andrewstuchlik
Community Visitor
Community Visitor
Make sure you are on frame 1 or zero when you create the passive collider, or it won't work properly.
