Nhair disappears when I play back
I create curves and assign a hair system - I do everything fine - hair looks fine - but when I play back the hair vanishes and only the curves are there ? The curves act as the hair should but the hair itself goes missing - why - frame 1 is fine but the rest the hair disappears- please help
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Can you tell me a bit more about your setup?
  1. What version of Maya are you working with?
  2. What is your Graphics Card?
  3. What Operating System are you working on?
  4. Have you tried resetting your preferences?
Lastly, are you able to share your scene file here? I'd be happy to take a look at it and see what's going on!
Thanks again for being a part of our community! I look forward to your reply!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
I have noticed that if i turn off the Nucleus the issues is gone and the hair shows up.
But don't i need the nucleus on?
Hi it happens with every scene i create, so its not the specific scene.
Maya 2016 student
Yoshmite on Mac
Not sure on Graphic card - but it's good enough, cause i saw it work before.
reset prefs, and no use.
Now i have some what solved it. after basically clicking every button, i found that when in the hair system shape1, i turned of the Nucleus, the hair stayed for the play back. and worked fine? but WHY
do i not need the Nucleus?
sean.heasley
Hi @Anonymous
Have you tried changing Viewports to legacy to see if the hair still shows?
Also, are you animating the hair or does it now show even if you assign it to a basic cube and hit play?
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Some things to try.
  • turn off collide
    • For the hairSystem
    • Or nRigid mesh close to the cv[0]
  • set hairsystem bend solver to "simple"
    • Save and reopen scene. (changing bend model requires a scene reopen)
