nCloth not simulating Maya 2023
StephJdsgn
StephJdsgn
Hello and thank you in advance.
I am unable to get the object to move/simulate/animate when using ncloth.
OSX 12.4
version:Maya 2023.1 Update - Mac
Update (2517.3MB). Released Jun 15, 2022
Error messages: none
Process:
new scene >create plane > Raise and expand plane to be higher and larger > select plane > Create nCloth.
nClothShape enabled
nucleus enabled
playback 24 frames  set to play all
Frames set  0-200
Press play nothing happens.   I went to YouTube to watch ncloth tutorials on inflating pillows (albeit old Maya versions)  drapes and table cloths followed them exactly. nothing simulates or moves.
increased frames. nothing moves.
sepu6
I'm pretty sure is because you have your playback set up as "realtime" and when you are doing dynamics it should be
"play every frame max real-time" or free
StephJdsgn
Thank you for your response, it is greatly appreciated!
I went back in with a new scene and a basic plane changed the playback settings and the object still does not move.
Hopes to find a resolution soon! 🙂
sepu6
Can you post your scene? is working fine here
StephJdsgn
Thank you for your time and continued assistance!
Here is a Gyazo screen recording
https://gyazo.com/661e1a4ae63928bfe6949d1ff992df03
sepu6
Is working fine here.  Maybe delete your prefs
