Announcements
How do I stop my objects from floating away
kaomihaines
kaomihaines
Hello I couldnt find a answer to my problem, I have domino like objects that i want to fall over, They are set as active rigid body then i use gravity field. However when my ball hits them they fall over but then they float away afterwards how do I stop them from floating away. Thanks in advance
sepu6
Post your scene, could be many things.
kaomihaines
sorry im new to this it not allowing me to upload my scene
sepu6
it needs to be a .ma  or .zip it
kaomihaines
oh okay here you go
sepu6
Not sure if you were using the prehistoric bullet system but your scene was bugged and I just re-did it with Mash which is way easier to do what you want to do and have more control.
I use your shapes already in the scene as an initial state for Mash so they stay in the same position as before then I added dynamics to both of them.
For the one with the pillars, I just check "initially sleeping" which in simple terms means that they wont be active until another object collides with them.
And I added the colliders on the bullet solver.
