Fluid emitter blending with grid color.
ratbite
ratbite
Hi guys,
I have a scene where I have 3 emitters in a container. The goal is the have emitters emitting separate colors and having the mixing with each other like ink in water. The issue I am having is the fluids mix with grey, or what ever color I flood the fluid grid with when emitting.
Is there a way to achieve the desired effect I want with in Maya Fluids?
I have the same problem that  fluid's color will turn grey
mspeer
Hi!
Because the Color Attribute of fluids does not have a transparent/alpha value it's not possible.
You can however achieve a similar effect by fine-tuning all Attributes contributing to final Density and Color.
(You can also set a different Color as starting/background-color for Fluids like black).
Other solutions are also possible, but far more complex.
ratbite
Thanks for your help mspeer! I will have to try that.
Out of curiosity what are the more complex methods and do they achieve results more to what I'm describing?
ratbite
It looks much better. There is still some fringing but it can edited in
post.
ratbite
post.
