When use the retime tool on a bunch of keyframes in an animation I get this problem where the key frame isn't sitting on any of the actual frames(See below). Is there away to do a batch recalculate of keyframes so they sit on the closest frame?
You can use "snap keyframes"
its in the key menu, and the time line menu
hth
-=s
Thanks for that. But was wondering if there is something more automated so I don't want to have to do it for every key frame in my animated character rig given there is 100s of key frames.
Cheers
Hi!
More automated than a single click in the menu as suggested by @stephenkmann ?
Just try it out, select your keys and use Snap or Snap Keys, you can find this tool/command in different windows and menus.
