Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Question about Blend Shape Function
2 REPLIES 2
hymwan5-c
280 Views, 2 Replies
Hi guys~
I'm recently following a rigging tutorial about making a tank tread, below is the video link:
https://www.youtube.com/watch?v=-pXAi7_Egho&list=PL7CVY-lQu6veDbhaxRs2RIvesKoveSr2K&index=21&ab_chan...
When it goes to the Blend Shape part, the 'tread' wired to the 'base curve' is supposed to blend from 'target 2' to 'target 1' when I rotate the 'rotationController' from 0 to -50 degrees. It really does but just by flipping it instead of animating what it should be like.
I have attached the MA file and a demo clip below. Hope you can give me some hints about it. Thank you~~
2 REPLIES 2
Baboonian
in reply to: hymwan5-c
Hi
this is because 'target1' was flipped, and then maybe frozen, idk. You should copy 'target3' and manually adjust the points
hymwan5-c
in reply to: Baboonian
I got it. Thanks! That helps me a lot!
