Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Question about Blend Shape Function
2 REPLIES 2
hymwan5-c
298 Views, 2 Replies
Hi guys~
I'm recently following a rigging tutorial about making a tank tread, below is the video link:
https://www.youtube.com/watch?v=-pXAi7_Egho&list=PL7CVY-lQu6veDbhaxRs2RIvesKoveSr2K&index=21&ab_chan...
When it goes to the Blend Shape part, the 'tread' wired to the 'base curve' is supposed to blend from 'target 2' to 'target 1' when I rotate the 'rotationController' from 0 to -50 degrees. It really does but just by flipping it instead of animating what it should be like.
I have attached the MA file and a demo clip below. Hope you can give me some hints about it. Thank you~~
2 REPLIES 2
Baboonian
in reply to: hymwan5-c
Hi
this is because 'target1' was flipped, and then maybe frozen, idk. You should copy 'target3' and manually adjust the points
hymwan5-c
in reply to: Baboonian
I got it. Thanks! That helps me a lot!
