Motion path?
This widget could not be displayed.
Motion path?
 have locators (with aim) in my scene. I have attached my locators to a curve (attach to motion path ) When I move the locators, I get this:
// Warning: file: C:/Program Files/Autodesk/Maya2013/scripts/startup/setNamedPanelLayout.mel line 151: Cycle on 'addDoubleLinear187.output' may not evaluate as expected.  (Use 'cycleCheck -e off' to disable this warning.) //
What exactly is cycle check and why is this an error?
If someone could explain this, I would greatly appreciate it.
it means that you have a value that affects another value that affects the original value - so you have a cyclic issue.
It could mean that the aim is affecting the curve that in turn is affecting the aim?
