Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Maya 2018 Quick Rig Keyframe Problem
5 REPLIES 5
5362 Views, 5 Replies
Hello!
Currently im working a mobile character rigged by "quick rig" but i have serious problem making animation.
My problem is when i set keyframe a controller, it set all the controllers same time and current positions. e.g : When i set a keyframe to right arm controller, it sets left arm, chest, hips, right leg, left leg controller too.  But when i set key to simple joint, its not affect other joints
I want to set keyframe to only selected controller, Is there a solution ?
ezgif-2-b70da678ee
5 REPLIES 5
kelly_hynes
In the Human IK window you can choose if you want keys to be set on the 'full body', 'body part', or 'selection'.  If you chose 'selection' mode, remember to switch back to body part or full body mode or your rig will appear to be locked in place.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
in reply to: kelly_hynes
Thank you very much! Problem solved.
you saved my life!
Kelly
Hello all!
I am having an animation problem while using Human IK. I select all of my controllers and create a pose. However, whenever I select one controller and delete the keyframe for that controller, it deletes all of the keyframes for the entire pose.
Any ideas why this happening and also how to fix this.
Thank you!
6 years late to this but thank you, it works!
